Old 02-02-2010, 09:07 AM   #17 (permalink)
90crxHF
Si engine and trans
90crxHF's Avatar
CRX Si/HF - '90 Honda CRX HF
90 day: 40.35 mpg (US)
Originally Posted by Ryland View Post
If you get the 165/60 R14 tires that the insight has they will be Low Rolling Resistance tires, also you should be able to get the lighter aluminum moon disc hub caps for around $100 used.
Dang, that will put me at 3600rpms at 70mph... With the 195/50-15 I was at 3400rpm at 70mph, and now with these 185/70-14 I'm at around 3200rpm at 70mph. I guess it really won't make much difference since I'm driving more around 60-65mph on the freeway now. I occasionally hit 70mph, but really only going downhill now.
Thanks so much for the replies guys. I will look into the pizza pan moon disc mod. I've already been thinking of doing that anyways, probably much cheaper, but I don't want it to look cheap. Know what I mean?
~1990 Honda CRX HF - ZC SOHC 1.6L non-VTEC, Si trans, Illuminas, Neuspeed Race
1/8th: 9.90 @ 71.03, 60' - 2.41 (HMP '08) - 284K on chassis and ~110k on engine
~1996 Mustang GTS/248A - 1/4: 13.447 @ 99.75, 60' - 1.820 (HRP - 959' DA)
http://www.nearlysurrounded.com <-- Check out my band
