Old 02-02-2010, 12:38 PM   #39 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
I was just teasing but the point is well taken about the vehicle idle overhead considering:
  • electric power steering - instead of a mechanical hydraulic pump
  • electric assisted braking - instead of a manifold vacuum and bellows
  • electric air conditioner compressor - instead of belt driven
  • electric water pump - instead of belt driven
Each of these loads will have peak values but even my 2003, NHW11 with daylight running lights on draws ~1.6A @275 V ~= 440 W. (the amps vary.) I haven't tried to measure the ZVW30, engine off load, yet, but from what I've seen of the systems, I suspect it is in the same range.
So putting things in perspective, the rule of thumb I use is ~250 wHr/mile for most vehicles. In an hour, the Prius idle electrical load would be almost 2 miles of travel. But I would caution that the additional load of power steering, braking, air conditioner and intermittent water pump could easily dwarf the idle overhead. A vehicle designer might see these as predominant and not think of the idle overhead as being significant.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
