Old 02-03-2010, 01:06 PM   #86 (permalink)
Daox
The plumbing will be pretty easy. I have an extra exhaust manifold that I'll be modifying to collect the gas out of. I also have an intake manifold from a Paseo with EGR that I can use to reintroduce the gas into the engine. I'll have to fab up stuff between, probably just use iron pipe.
I will have to run coolant to the EGR cooler. I'll likely just grab that off the throttle body coolant lines.
