Regarding the axle ratio -
It turns out that my Father actually has an 80-something F150 with an axle tag that says 18. Yep, 3.08 ratios.
Caveat - They broke the rear end about 13 years ago, and he doesn't know if they actually replaced it with a 3.08 or not. I can at least get the front diff, though, since I know that's still OE.
Guess I'll have to count teeth on that rearend and hope for the best?
I've looked around and found that I should be counting 40/13 to get a 3.08 ratio.
Turns out I have a Dana44 front axle, as well. Gonna see if I can find anything lower than 3.08 for the D44.
Darn. I'm not seeing anything lower than a 3.08 without going to a completely different front axle, and as much as I'd prefer a solid axle, I'm not doing that much fab work. 3.08 it is!
Looks like I won't be able to use big-truck tires, either. The 9.00-20's are 40" tires, and that's wayyyy too big!!!
I guess I'll stick with 15's, and just get some stock steel 7.5" rims and use the stock 235/75 tire.
