Old 02-03-2010, 10:52 PM   #27 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Unless you raid the axle off an older Cadillac Fleetwood, even 3.08s are hard to find. The aftermarket no longer supplies the 3.08 set I have.
Bigger diameter tires will hurt you mileage. Stick with the OEM size tires. Sizing tires is one thing the OEMs do well.
I have talked to hundreds of truck guys and the story is always the same.
Bigger diameter = lower MPG.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
