Originally Posted by shovel
Efficient is not the issue? I guess then I don't understand what end result you are looking for. Are you trying to make a gasoline powered charger for an electric car? Efficient matters at both ends, doesn't it?
We could have a 2nd gasoline engine run the alternators, sure... or a thousand treadmills, or a windmill, the alternators don't care what is spinning them or where it's located...
If you are trying to charge a series bank of batteries by using multiple 12v alternators, I think you'll find that it won't work just as straightforward as that because all the alternators will want to have a common ground, which will short your series batteries.
Efficient is the issue....but not for the main engine(thats more than this thread can handle)
A gas car keeps a battery going a......
excuse me for my leap into the unknown
but with a timed circuit of sort,cant you do what a car does with out shorting out the series ...' from my understanding the alternator keeps the battery at about 13+ volt' to keep it at proper level for longevity .... maybe im just beating a dead rock.....lol...(im not the brightest rock tossed into the pond....lol)...but with a circuit it seems like that would stop the problem of shorting.
i.e. ...
a home generator can accept multiple sources of power at once .....wind,sun,electric company and more...and it knows how to handle it....all in one process i believe...it just passes the correct energy to the work load or to the batteries (that are series wired i believe )and why car audio people dont have it yet i dont understand.car people from my dayz r alwys adding more batterries and alternatorsinstead of just putting in a 5 lb invertor,industy brushes and getting more than enuff power for the show off..not trying to side track
but i know u can put a a regular sound system in a car and show off you sounds.....but in thought of using alternators......there has to be a way....for real world use.
dont get me wrong...please....but if u have a way to power your audio.....why not .....
omy is the turning into a audio/video mod talk
