Old 02-04-2010, 10:43 AM   #96 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Ok, I need to question something, because I'm not sure I fully understand what's being done here.
Are you using the EGR flow to enable lean burn under normal circumstances, or are you using the EGR flow as a "filler" to lower effective displacement?
I would guess that with a variable valve, you're doing the latter.
