Old 02-04-2010, 11:57 PM   #72 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Update...
Engine is back in. Started the mock up on the D16 with a custom top mount and a HE 351CW turbo. It will have a dual purpose 4" up-pipe (open verses closed) I'm building a 4" v band flange cap that will be easy to remove at the drags then put back on for the drive home. It will have a 2 1/2" down pipe to the regular exhaust. It will also have wastegate controlled EGR valve for fine tuning. Lots of welding ahead
Pressure Gradient Force
The Positive Side of the Number Line
