Old 02-05-2010, 12:43 PM   #5 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Rotary injection pumps are lubricated by fuel. You need to be absolutely sure that shutting off the fuel solenoid doesn't affect lubrication of the pump. Your switch would not be an issue if you were shutting the engine off with it, but if your goal is compression braking, I'd do more research. Spinning a dry rotary injection pump is something you will regret. You might want to talk to a diesel shop that rebuilds Bosch rotary pumps.
