I regularly pulse starting as low as 1200 rpm. My driving is all pulse & glide, as well, so that happens often. Cruising is much lighter load - I sometimes cruise down below 1000 rpm with light load. 175,000 miles and my engine is doing fine.
I like to look at the rpm and gear selection from a miles / engine revolution perspective. The higher the gear you can run, the fewer engine cycles per distance traveled.
