Old 02-09-2010, 07:25 AM   #15 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Originally Posted by bestclimb View Post
I lope along at 1000 rpm frequently l, 5th gear and mph, the engine is smooth so no worries. If I try to increase my speed and the engine vibrates it means I am applying too much pressure to the accelerator or I need to down shift.
Very good point - at low load, you can go all the way down to idle. When you open up the gas, though, it starts shuddering at that same rpm.
My experience: I've yet to find a car where (in real world circumstances) the best cruising fuel economy isn't in the highest gear possible without lugging. I don't think the "best" engine RPM/load window is hard to find.
At cruise, the rule of thumb is: upshift, unless it lugs.
I concur.
Originally Posted by greasemonkee
What about when it shifts into open loop or sub stoichiometeric operation? Seems like an economy loss would be eminent once that occurs.
Also a good point. I know, from the Scangauge, that my car goes into Open Loop at >95% LOD - pedal all the way to the floor. I monitor that gauge and keep it below that point.
