You can make inserts that cover only the area that is actually OPEN on the grill.
Also, you can make a panel or two that directs the air from the grill directly to the radiator, it'll help make better use of what cooling capacity you do have.
Being a Dodge Automatic (I know, I've owned 13 Dodges 11 autos) DO NOT COVER that transmission cooler. It barely does it's job as it stands!
- Greg
