Old 02-10-2010, 02:52 AM   #21 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
You're going tank by tank and testing mods with each tank?
Why not try eliminating some variables and running each mod for more than one tank?
If you get a 5% increase from a mod, with your 22mpg, it's only going to equate to ~1mpg, Mike.
You'll likely dismiss it as "noise", but you'll have a better test bed if you had some sort of instrumentation that could quantify changes in the way your vehicle operates, even a vacuum gauge. IF you're getting better MPG, you should notice lower vacuum numbers while cruising.
Stickers is remarkably clean underneath, by the way.
