Old 02-11-2010, 01:10 AM   #31 (permalink)
stonebreaker
stonebreaker's Avatar
Originally Posted by Christ View Post
Once again, the pipe doesn't need to be 18 feet to benefit from scavenging. That's the "ideal" length for a given engine size at WOT flow, assuming (I believe) 100% VE.
WOT or not, it doesn't matter. The length of the pipe is determined by rpm. Pipe diameter is determined by engine displacement.
In reality, that wouldn't be happening most of the time, and considerations could be made to take advantage of pulse scavenging, although not in the most ideal sense.
Harmonics are a different beast altogether, and can be taken advantage of on increasingly smaller amounts after primary harmonics, but can still be usable by length/cross section tuning.
No, you can't. 2000 rpm is too slow to make use of pulse scavenging in a streetable car.
