Old 02-11-2010, 03:36 PM   #13 (permalink)
jfitzpat
jjf - thanks for the oil info. Seems to me that if one is going to extended change intervals with synth, regularly scheduled filter changes might address the issue, no?
Partially. It removes particulates, but not any leaching contaminates. Most the newer synthetics actually address this chemically, but some of the older ones do not.
I guess the science would be, synthetic oil + regular filter changes is very reasonable. On the far more subjective front, I'm a regular oil change guy. I don't have controlled data to back it up, but I know I got 100K out of vehicles when it was rare, consistently get 250K-300K now, and have taken a number of light aircraft engines far beyond recommended TBO.
Interestedly, the only time I didn't get great engine life between rebuilds was my first experience with synthetic oil in aircraft usage, but everyone had that problem, so it was a rebuild I didn't have to pay for!
I can confirm that the SG reports loop status directly from the ECU; it's not inferred from other sensor readings.
I didn't think it did, though if it has just has one indicator, I presume it combines the multiple indicator bits from the PID.
And I agree, puddleglum: some cars go to closed loop really quickly, even in sub-sub-zero conditions. My Firefly does; but others have reported longer transition times.
See my post above, it is still a good indicator of when the ECU thinks that head temps and the flame front are in normal operating range.
I do sometimes monitor it when pulsing at high load to prevent going into fuel enrichment).
A good idea.
-jjf
