Originally Posted by nj1266
How did you do your calculations? Did you you do them manually or rely on SGII? I had my SGII telling me that I was getting 34.xx mpg to the tank on my S2000, but when I filled up from the same gas station/pump and manually calculated the mpg it was 30.27 mpg. Ofcourse, this was before I calibrated the SGII. Now that I have it calibrated, I am hoping that my manually calculated mpg matchs the SGII tank mpg.
My readout (car readout) says i'm doing 30.8 mpg. I don't have a scanguage.
I worked it out as:
£22.55 spent
£1.08.9 per litre
20.7070707 litres
20.7 litres / 4.54609188 (UK imperial gallon)
= 4.55491689 gallons
200 miles / 4.5 gallons = 44.4444444 mpg
Working it out in US gallons appears to be a bit worse though - only 36/7 mpg. Oh well, either way it's a definite improvement.
