Old 02-13-2010, 10:20 AM   #72 (permalink)
itsmedc
Apologies for resurrecting an older thread.
One thing I "discovered" after losing the lug bolts and wheel on a pop-up camper I was pulling is that little trailer lug bolts are supposed to use a thread locker chemical (like loctite blue). The ones at the camper dealer actually come pre-treated with a dry form of loctite on the bolt. That is in addition to being properly torqued to a fairly high number. Mine were supposed to be 85 lb ft and that is with the thread locker treatment.
The Following User Says Thank You to itsmedc For This Useful Post:
aerohead (02-13-2010)
