After learning a lot of tricks from you guys over the past year, i have been gradually modifying my 08 liberty aka GasHOG, here is the progress so far:
The obvious Fia grill block, warms up the truck a lot faster:
Honda ridgeline style diffusers on the mirror:
Added Front and rear tire air deflectors, I tried to put a bigger air dam up front, but after numerous failed attempts, I just put inverted mudflaps and happy as to how they turned out:
Side view:
Rear tire deflector, it looks a lot bigger than it actually is, but i may trim it a little more:
Rear kammback, ordered a 48"x 12" smoked plexiglass, It was a nightmare to bend with a heat gun. In hindsight, I should not have ordered the 1/4" one as it is too thick, but the rear of the liberty has these 1/4" ridges and i notched the plexiglass at either ends to fit it flush with the ridges so that it stays on the roof line. The clips are just there temporarily till the acrylic foam tape cures.
Its in line with the roof:
Side view:
Any comments and constructive criticism is always welcome
