Old 02-15-2010, 11:42 AM   #261 (permalink)
jackbauer
jackbauer's Avatar
Here a few pics of the charger in operation. First pic is running in bulk mode with a 10amp current limit. Second pic in float mode. I had to limit the charge to 10amps due to the poor main service where i work on the car. Was actually causing the lights to dim
ID:	5608   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
