Old 03-25-2008, 11:50 PM   #17 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
fabrio -
Originally Posted by fabrio. View Post
about the the FWS, what you of thoughts?
I could not understand how to use the plastic waste basket shapes until I saw your pictures. At first I thought that the "coverage" of the front wheels was not enough. I thought it was too shallow because the commercial ones are a "flat rectangle". But, the longer I look at yours, the better I think they are. They are covering the suspension/linkage, so that is good. Aesthetically I think they are very good.
For the rear wheel FWS, I don't know. This is the first time I saw someone use the "flat vertical guide" behind the wheel. I think there should be something in front of the rear wheel leading the air to the rear FWS. Does that make sense?
Also, I think you should go find a Prius. Behind the rear wheel is a special shape. Imagine the hull of a toy plastic boat. Then turn it upside down and stick it behind the rear wheel. Here is what I mean :
Maybe this is why they call it a "boat tail", .
I appreciate your pictures because they are very detailed.
CarloSW2
American Solar Energy Society
