If it can be used as a truck, it's a truck. The Ranger hauls 1000lbs in the bed and can tow up to 6000lbs. Anything larger is just wasteful, unless you own a construction company or something.
By the same definition (can be used as a truck), most compact hatchbacks are also a truck once you install a tow hitch.
