Originally Posted by Daox
I'd go for the scangauge. The mpguino is great for preOBDII, but the SG just has so many more features.
Accuracy can be tweaked pretty close, but you really just need to get a baseline. From the baseline you can tell if you are doing better or worse.
Scangauge. We're in the same side. I totally agree. I can't say more. Be sure to check if your car is OBD compliant
