Had a thought (I know I know!). One of the big concerns with a dc controller is a short circuit failure in the power section leading to a runaway motor or vehicle. What about having a section in the micro firmware where by if the throttle is at zero and the ramp down period is over it looks at the lem. If the lem reports a significant current flow then open the main contactor. Obviously have a little bit of a time delay and some self checking built into the routine. Thoughts?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
