Originally Posted by 3-Wheeler
1) Position the car to that it faces straight on the driveway.
a) this was verified by opening the driver door and aligning the step with the edge of the driveway. I had to move the car back and forth manually to accomplish this.
Before you get too far along with this data, you should verify that the two door steps are parallel (i.e. they are parallel to the car centerline). You should be able to do this by quickly measuring between the two steps at two different points with a steel tape. Perhaps you have done this already.
