Originally Posted by thatguitarguy
If you have a circular saw you can kerf the inside of a sheet of Masonite and it will curve a lot easier. Masonite is about 1/8" thick, so set the saw to about 1/16" deep and cut lines 1" apart perpendicular to the way you want the board to curve, or for a curved edge you can cut the lines closer together.
Good tip. A guy could probably tighten the curvature down to a foot, possible less. I don't see that making compound curvature possible though. Still, good idea for some.
Cheers
KB
