Old 02-22-2010, 05:38 PM   #11 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Coroplast is found on election signs, in season, or at lumberyards for under $20/sheet. However, you can do fine with masonite, too. Just soak the outside of the curve with warm water, and it will soften up fine. For corners, you might screw it onto plastic plumbing pipe.
