Old 03-26-2008, 06:36 PM   #25 (permalink)
fabrio.
fabrio.'s Avatar
tigra AERO - '96 opel tigra
Originally Posted by basjoos View Post
Fabrio, The "mini-boattails" behind my rear wheels are 30cm long and 12cm high. It looks like you might have room to install them behind your rear wheels. Even if you don't have the length to install a full-sized mini-boattail to block the entire width of your tire, you could make a shorter, reduced-width boattail to block part of the tire's width. That would be better than having nothing behind the tire to fill in the wake.
You might also consider installing double side skirts between the front and back wheels to help keep the air flow linear between the front and rear wheels.
I recently painted black my front wheel air deflecter, smooth hub caps, side skirts, and mini-boattail, so with the white front and rear wheel well skirts installed on my car and everything below that black so you can't see the wheels, from the distance my car looks like it is wheel-less and hovering.
I want to make changes you advice me, but my girlfriend kill me
What I can do, is build something barely visible.
Good, your idea to paint some elements ...I can to tray it, but if you do not see me more, you know the why
Seriously, now, I will go to mesure the rear end of my car for study this possibility.
I wanted to ask you how you developed the "mini-boattails" than your posted in your original post.
You speek of pattern, how this help you?
