rbowning -
Here's the Green Car Congress version of same :
Green Car Congress: Opel Flextreme GT/E Extended Range Electric Vehicle Concept to Debut at Geneva Show
The Flextreme GT/E also explores the potential for active shape shifting. At speeds above 50 km/h, a vertical panel extends along the body from the air extraction slot behind each rear wheel-arch. These 350 mm-long side spoilers guide high-speed airflow around the rear corners of the car, further reducing the amount of turbulence.
Mass reduction measures for the body include the use of lightweight, carbon composite outer panels, polycarbonate window glazing and aluminum alloy structural components. Compared to conventional materials, these offer a 40% weight saving which further contributes to reduced energy consumption and an increased driving range.
I don't mind the shape-shifting part because we already have active-spoilers for cars like the new VW Beetles. It's just concept-bling that may not see the light of day anyway. Make it a bling option for more $$ and/or an Eco-package-bling option?!?!?! Ha ha, you could put your an advertisement on it that only shows up above X-mph, orrrrrrrrrr, covers an advertisement at X-mph, or BOTH!!!!
CarloSW2
