Old 02-22-2010, 09:55 PM   #19 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Although I don't see it on the net much there are places that make solar cooling systems. They do not use electricity to make the "cool" and are much more efficient/cost effective than using PV to make solar cooling, in fact there is one place making both portable solar vacine refridgerators for 3rd world countries and large scale business solar cooling systems in the Wausau business incubator.
If you have a junked out gas powered refridgerator you can use the sun coupled with a big screen magnifyer to make your own passive AC albeit much less efficient but still cheaper than PV cooling.
Cheers
Ryan
Originally Posted by cfg83 View Post
NeilBlanchard -
I will go check them out. How many panels would it take to run one 110 volt wall-mounted AC unit like this? :
Quick calcs :
5,050 BTU AC uses ? watts/110 volts = 20 amps
=> 20 * 110 = 2200 watts
=> 2200 / 175 watts per panel = 12.5 panels
=> 13 panels
=> $11,700
Nevermind ...
CarloSW2
