Originally Posted by jimepting
Before you get too far along with this data, you should verify that the two door steps are parallel (i.e. they are parallel to the car centerline). You should be able to do this by quickly measuring between the two steps at two different points with a steel tape. Perhaps you have done this already.
Actually, I also checked the alignment of the tires.
As you know, the Insight has rear tires that are inset by 2 inches over the front tires.
I moved the car until the rear tires were two inches further away from the edge of the driveway slab that the car was resting on.
When moving the car, I noticed that the rail where the drivers door opens was also in alignment with the driveway edge.
Jim.
