Originally Posted by basjoos
I have my back up lights shining through a clear panel on the underside of my boattail. They are 2 tractor work lights, so they are bright. On my boattail, I only have the license plate, license plate lights, and turn signal lights mounted at the tip of the boattail. The tail lights are mounted under a clear panel at the back of the upper surface of the boattail and the back up lights are mounted at the back of the lower surface of the boattail. This is how I solved my problem of having not enough surface area at the tip of the boattail to mount all of the rear lighting functions. Also have a line of marker lights and a turn signal light running up along each side of the boattail to get full width illumination from the rear. All of the lights in the boat tail except for the back up lights are LED.
Hi Bajoos,
Nice to hear from you.
Now to some questions...
You might recognize this picture. It was taken by yours truly at HybridFest in Madison last summer.
Can you elaborate on each of the lights highlighted in this picture?
And what is that object, located at (6)??
Also, are your backup lights actually mounted underneath the extension, and facing the ground?
Where did you source the lights from?
Thanks, Jim.
