Hi Paul,
Great work on all of this. You're making me very excited about the open3phase and higher power version of this controller.
I'm reading through the installation instructions dreaming about making the controller. I've noticed a few totally minor issues (hope you don't mind). They're pretty mild issues though- i'll warn you. :P
Page 14 - it'd be better to use heat shrink. I find that after a while (esp in hot environments) the tape will unwind.
Page 17 - the little clips are fit over the cable inside the shell, so that if you pull the cable and its attached it won't break the connections. It ads strength to the cable.
Take Care,
Haydon
