Thread: Cam help?
Old 02-26-2010, 09:41 AM   #26 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by micondie View Post
If you check the specs from Comp Cam you see that the lift and duration are the same for the intake & the exhaust. With modern CNC technology there would be no problem grinding them differently if there was an advantage to do so which leads me to conclude there would be no advantage to just changing the intake rocker. although considering the ease of changing them I personally would try just the intakes first and document the results before changing the exhaust rockers. Perhaps if fuel economy is the main goal, not increasing low end power which is Comp Cam's goal, this approach might show some gains.
I'm not sure if I can do that with the EFI head, but w/ the carb'd head, I think I can. They changed the rocker design in the '85+ models to pedestal mount, instead of stud mount, so I'd either need machining work or a special bedplate to mount them on, and that's not something I want to do twice!
However, Comp's RV (low end torque/gas mileage) cam claims improved gas mileage as well as increased low-end torque, so once I can find the OE specs for the cam (I'll have to keep searching, haven't found it yet.), I'll compare the rocker increase to Comp's low-end cam, and see how they compare.
Maybe the rocker increase will get me something in a close approximation to the RV cam for less than half the price/work, which is the ultimate goal, for me anyway.
I would suggest that I build one of the carb'd heads I have laying around for the purpose, and just change it when I need a new head gasket, but that's not likely to happen any time soon... the I6's can go more than 300k between rebuilds, and then it's just rings and bearings/seals, usually.
