Old 02-26-2010, 11:27 AM   #5 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Bicycle Bob View Post
The XFI had all black bumpers, but you'd have to count the turns in and out to be sure of a tranny model, AFAIK. The 8-valve had the same ratio, which may be easier to find.
Base model Metros had black bumpers too. Only the LSi had the body-colored bumpers.
And the 8-valve 89-94 Swift tranny is not the same as the XFi tranny. It's a taller final drive than the XFi. 3.52 for the 8-valve Swift vs 3.79 for the XFi. Neither are easy to find, use the 3.52 if you can get it. The 1995+ Metro and Swift with the 4-cyl have the same final drive as the XFi, and those are easy to find.
Count the ring gear teeth if you want to be accurate. XFi ratio tranny will have 72 teeth. And the super-tall 3.52 Swift tranny will have 74 teeth on the ring gear. Remove the triangular metal plate to count the teeth.
