I'll add use good winter tires, as the less spinning of wheels the better. Drive in tracks already made where able, slow down as sliding is usually a waste of energy.
Install in addition to the block heater a circulating coolant heater and a small blowing heater to heat the cabin up before you start up. Run those for a couple hours before you drive. They can all plugged into a three way outlet that way you only plug in one cord, but be sure that the cord and the threeway is rated for a bit over the combined wattage of all your heaters.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
