Thread: 500k
Old 03-01-2010, 07:25 PM   #34 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
If the car uses a quart every 1000-1200 miles why do you change the oil at all? Even with a 5 quart capacity, you're changing the oil within the recommended change range.
Is it burning the oil or leaking it, or both? If it leaks would fixing the leaks reduce consumption significantly?
Good design is simple. Getting there isn't.
