can you open and close the feild circuit "on the fly" without damaging the alternator? what about a switch mounted on the throttle that closes the feild circuit when you are coasting, or is that the wrong time to hit a charge cycle. id like to make it automatic instead of adding another thing to do while driving,,,(i dont think i can make it to work 55miles) in the summer with a/c,, without any charging, and in fl 100+% humidity and 95+ temps i will have to run a/c,, dont want to smell on arrival. might have to go with an underdrive pully if all else fails.
Reason: fact wrong
