Old 03-02-2010, 11:51 AM   #3036 (permalink)
williamson
Has anyone researched a CPU cooler? It uses heat-pipes to transfer the heat. The pipes contain a liquid, most likely alcohol, that evaporates and absorbs a lot of heat. The fan then condenses it back. I would guess this must be operated with a designated side down, so the liquid flows. They are sold cheap on ebay. Such as # 160407436678. Of course, it's small. BTW, in case anyone wants to know trivia, the miller capacitance is the multiplication of the real gate to drain capacitance, by the drain voltage rise. It slows the turn-off.
