Old 03-02-2010, 12:05 PM   #11 (permalink)
kubark42
Originally Posted by McTimson View Post
I'd definitely be interested in installing one of these, the only problem for me would be finding the GPS unit. I don't know anything about them, so I'm not really sure what to look for in buying one. I already have an MPGuino set up, so those wires are already tapped, and I have access to Matlab.
Do you know the typical power draw of the GPS units?
It's a pretty large market out there, so it ranges all over the map. The FV-M8 that I have uses about 60mA. The u-blox use about 40mA.
However, one of the reasons I like the u-blox is because it has some nifty shut-down features that let it go to sleep and wake up periodically, all on its own, so power usage becomes much less important. Here's the link: www.lemosint.com/gps/gps_details.php?itemID=571
(Note that if you wanted something like that, you'd have to be able to do some programming in order to support the extended features. It's pretty easy, and I can advise, of course, but without having the GPS unit in front of me I'd be a bit limited. Are you comfortable with that?)
