Darin - Technically, adjustable cam gears have a basically infinite adjustment, because while they're usually only indexed for 7-14* in each direction, each tooth is typically only slightly more or less than that on the cog.
The result is that you can move the cog a tooth in the direction you want and "back tune" to get those few degrees back.
For instance, one of the Honda engines I had (d series, not sure which one) was 19/32 crank/cam.
360/32=11.25, and with 14* of adjustability, I can make up for an entire tooth this way.
