Hmmm I see appeals to emotion on both side of the ANWR issue. It is I think nearly impossible to remain impartial and unjadded by preconceived notions. Best thing you can do is evaluate yourself and see what propaganda is coloring your judgment of an issue try to learn the facts and make your own choices based on what you value, and what the perceived risks are and how likely they are.
The other issue I see with emotional issues is that it is very easy to dismiss as evil, misled or stupid anyone who does not happen to hold your same ideological view. That may even be potently embarrassing when it may be that they may actually be the one holding the high ground of reality.
As far as if we should be drilling in ANWR a good starting point may be to look at similar environments where development has taken place, see what the direct and indirect results of that development and take what we learned from that and make a value judgment of the effects of that action and build from that.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
