Old 03-03-2010, 08:33 AM   #2 (permalink)
Daox
If you simply add a vacuum tank to the car you could easily double the amount of 'vacuum' you have available. The pump IMO is overkill. Some members here have simply taken a PVC pipe, put caps on both ends, and then drill/screw a barbed fitting into one of the caps and connected it to the brake booster (or any place behind the check valve).
