Originally Posted by TheSGC
I want hear about long, abusive runs! ![Big Grin](/forum/images/smilies/biggrin.gif) Your BMW is similar to my Civic, (96 volts setup) so I am really curious on what your range and performance is with those batteries, and how the charger works out at 40 AMPs.
Hey Dave,
Jacks problem right now is he doesn't have a service big enough that is readily accessible to power the charger that wont cause a tripped breaker or the light dimming!!
Also, right now he only has 48V (4 batteries), but is getting 6 more very shortly.
I dont know how much you have done on your charger already, But I have a PCB of this charger all drawn out in eagle that I will be proto-typing in the next few weeks. Im working on a kit basically that this will be the logic, you supply the power stage which is just a rectifier, caps, IGBT, and inductor.
I could use a beta tester that is local...your only an hour away...If your interested.
-Adam
