Old 03-05-2010, 12:27 AM   #28 (permalink)
Otto
... After reaching maximum cross-section,even with turbulent boundary layer,the flow cannot tolerate radical pressure gradients.
The aft-body has got to taper gently allowing flow deceleration for pressure recovery.Too steep,and it separates,and the base pressure will be the same as at the point of separation.
NASA guy told me ~8 degrees was max slope on aft body, to avoid undue separation and turbulence. German sailplane research showed essentially that, as seen in oil smear tests in wind tunnel.
