Originally Posted by Old Tele man
...DISI using pressure to heat the fuel.
...one major benefit is no fuel vapor in the intake manifold--only in the cylinder--so the intake air is denser, which allows the compression ratio to be bumped up a little bit more for the same octance fuel.
Increased VE per stroke, as well.
