Originally Posted by ccrider
kamperbob the tailgate was closed during the tests. not sure if that is what you are asking. but the back of the cap has a piece of plywood on it.
Good. I meant the cap not the tailgate. (I was wondering about possible reduced pressure *inside* the cap (vacuum effect) acting on large vertical surfaces, but if the cap was closed that should not be a factor.)
Cheers
KB
