Originally Posted by ccrider
the truck is slightly lower in the front in the picture if you look at the black bed liner under the cap compared to the template bottom. if the truck is perfectly flat the template matches up pretty close.
Thought that might be the case. The bed rail shows a bit of a downward angle in the image.
