Old 03-05-2010, 11:41 PM   #12 (permalink)
turbobob_01
Ok, I keep reading this over and over... "So my solution involved a couple of 1k resistors. I ran one from switched 12V to the vss wire. And another from the VSS wire to ground.", ...but am not clear on it.
I wish I could draw you a diagram, but I am not that computer smart either. Do I connect both of these resistors in parallel directly onto the VSS wire? It makes me a bit nervous to add voltage to a circuit. I am trying my best to understand what this will do. Thanks for your patience with me.
