Well the charger will fullfill all 4 of your requirements as is. Regards battery monitoring I use a Victron BMV602 which can be used to log data to a website and send and receive sms messages to a phone relating to battery parameters. Also can be hooked up to a laptop and download historical data such as deepest discharge etc.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
