Thread: Hello... again.
Old 03-06-2010, 01:35 PM   #2 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
chaster -
Welcome to EM! You made me look :
The SPARC – XEV Project - Xenopi Studios
SPARC XEV Current Configuration Technical Data
Configuration: 2F3T Tandem
Max # Passengers: 2
Overall Length: ~114″
Wheelbase: ~90″
Track Width: ~44″
Suspension: Independent Coil-over gas shocks on all 3 wheels.
Braking: multi-pot Hydraulic Disc brakes on all 3 wheels
Frame Construction: Aircraft grade high strength Aluminum Tube with high strength Steel for critical components. Integrated roll bar.
Body Construction: Composite with reinforced side impact beams.
Vehicle Total Weight (projected): ~700 lbs.
Target Cd: < 0.2
Drive Motor: AC-31 Induction with Regen running at 72V.
Motor Controller: Curtis AC Controller
Prototype Battery Pack (~1/2 maximum capacity): 7.2kWH LiFePO4
Battery Monitoring System (BMS): eLithion Lithiumate
Charger: DeltaQ 72V 1KW LiFePO4 onboard charger.
CarloSW2
American Solar Energy Society
